Flashlight Review, Fenix TK60
Discussion in 'Gear Reviews' started by erns, Jun 21, 2011.
    erns Loaded Pockets
    I purchased the Fenix TK60 from Fenix Outfitters.
    Comes with a carrying strap, extension tube and spare o-rings.
    Uses 4D sized batteries with extender on.
    Uses an XM-L Led.
    SMO (Smooth) Reflector.
    I believe it's an AR Coated lens. I can tell when I have the TK60 on and look from the side I can see some blue color in the glass.
    Rear view of the head.
    The left button is for the changing the levels. The levels are low, medium, high then turbo. when in strobe you can click into SOS.
    The right button is to turn on the TK60. It's a reverse clickie. If you double click it goes into a "debilitating" strobe. The strobe in high really seems to mess with my eyes!
    The threads are square and were generously lubed. The extender threads weren't lubed.
    Inside view of the tail cap.
    Tail stands
    Carrying Strap installed
    These are the Lumens and run times from Fenix:
    Turbo - 800 Lumens - 4hrs 16min
    High - 350 Lumens - 12Hrs
    Medium - 111 Lumens - 40hsr
    Low - 10 Lumens - 400hrs
    Strobe - 800 Lumens
    SOS - 111 Lumens
    It says Fenix Products are strictly in line with ANSI Standard. The testing Data more scientific and specific. I don't know what all this means?
    I took Lux readings with the Tenergy D Sized 10,000mAh Nimh Batteries fully charged. I used my Meterman LM631 Light Meter.
    These are the batteries I used.
    Fenix TK60, Turbo - 45,936 Lux @ 1 Meter
    Fenix TK60, High - 15,280 Lux @ 1 Meter
    Fenix TK60, Medium - 4,680 Lux @ 1 Meter
    Fenix TK60, Low - 370 Lux @ 1 Meter
    Fenix TK60 @ 96"
    Fenix TK60, Low @ 32'
    Fenix TK60, Medium @ 32'
    Fenix TK60, High @ 32'
    Fenix T60, Turbo @ 32'
    Fenix T60, Turbo @ 146' or 44.5 meters
    Fenix T60, Turbo @ 210' or 64 meters
    The next outdoor beam shots are at distances not measured.
    The Fenix TK60 is a very excellent made light. Threads are square and generously lubed. The threads feel smooth but are tight.The finish is Type III Hard Anodize and is excellent with good color matching and no flaws.
    The hot spot on the bean is very white. Outside the hot spot has a very slight green tint. It's the brightest XM-L light that I have. I have 5 XM-L lights and 4 of them are "throwers". I knew when I first turned on the TK60 it was going to be the brightest.
    In strobe mode the TK60 had the strongest effect on my eyes. As I said earlier it's "debilitating"! I was looking at it about 5 feet from my wall.
    I did notice the lens looks to have an AR Coating. When I turn on the light and look too the side of the lens I can see some blue in it.
    It does take a second to find the on switch. I hold it and rotate the TK60 to find the switch.
    Not bad run times as told by Fenix. Turbo - 800 Lumens - 4hrs 16min. I like to run my lights in high.
    The Fenix TK60 is a very long light and has some weight to it.
    Fenix did an excellent job with this light.
    Cost of the Fenix TK60 was $110.65. I got 10% off a Twitter special.
    Monocrom Loaded Pockets
    Very impressive review, erns.
    And I thought the TK50 was nice.
    Just the thing for those who miss the heft of their 3D or 4D Maglites.
    CDavisJK Loaded Pockets
    Awesome review. I love all of the pictures. I'm hoping to get a CR123 powered TK35 which has similar output. So, the pictures just make me want it more :D
    tower Loaded Pockets
    Awesome! It's the mother of all LEDs. With the same (or barely higher) output in much, much, much more compact sizes, I'll stick with my TK-35 and 4Sevens Maelstrom S12. Only 1.5 hrs run time on highest setting, but for the size & weight savings, I'll take it. The 60 kicks butt on run time. If I had one, I would definitely look at rechargeables for cost effectiveness and brightest output.
    ww2fanatic Loaded Pockets
    what is the extender for from 3d to 4d's? Also do you think you can run turbo off of 4 alkaline d's?
    erns Loaded Pockets
    I did a quick check with the 4D vs the 3D batteries. The batteries weren't fully charged. I got the same lux readings in Turbo with the 4D vs the 3D batteries.
    The lux readings I got were both at 45,425 Lux @ 1 Meter.
    Surprising. Maybe the extra battery increases the run time.
